Hey, so I got a simple, yet quite unusual problem. When I receive a call and answer it, I can hear the caller but the other party can't hear me, BUT when I call someone, it's completely fine. Any ideas?
Edit: I have exynos version of Samsung Note 9 if it helps with anything
Edited by Adamator_Cz
https://linustechtips.com/topic/1277721-problems-in-calls/
I would try resetting app preferences under Settings > Apps > Dots menu. Maybe also clear network settings in Settings > General Management > Reset > Reset Network.
Also check your permissions for the Phone app (regarding mic) although this probably isn't the solution.
You could also try clearing your dalvik cache (shouldn't erase data, but BACK UP PLEASE!!!):
https://www.t-mobile.com/support/devices/android/samsung-galaxy-s9/wipe-cache-partition-samsung-galaxy-s9
Some people have found that Deep Cleaning with CCleaner works too, worth a shot.
You could also always reset the phone and test it in an "out of the box" condition.
Technology advances at such a smooth rate as to render us unaware of major leaps forward. It is only when we look back on our memories that we see the true majesty of the world we have created.
https://linustechtips.com/topic/1277721-problems-in-calls/#findComment-14295729
