Recently I purchased an NVME drive (https://shop.westerndigital.com/products/internal-drives/wd-black-sn750-nvme-ssd#WDS500G3X0C) to replace my current SSD in terms of storing windows. However the NVME isn't showing in bios, disk management or even WD's dashboard. I'm fairly certain its compatible with my motherboard; Asus Strix-f B350 Gaming motherboard.
The manual says that with Ryzen Processors it has " -1 x M.2 Socket 3 with M Key, type 2242,2260,2280,22110 storage devices support (SATA and PCIe 3.0 x4 mode" and I've made sure I don't have any drives plugged into ports 5 and 6 as it disables those when you have a M.2 installed.
Honestly I've tried everything at this point, bios is updated, so is windows, I've made sure its slotted correctly. I just got over a memory leak and really don't wanna have to work on this long, any thoughts? Is it even compatible with my motherboard?
https://linustechtips.com/topic/1277257-nvme-compatability-problem/
