So recently I had purchased a new motherboard, the MSI B450 tomahawk max, I also purchased two sticks of RAM, Corsair CMK16GXM2B3200C16 vengeance LPX (x2 8gb). I already had the exact same x2 RAM sticks in me previous setup and they ran at 3200mhz. After installing the new motherboard and the 2 new RAM sticks, the computer booted up fine, I went into the BIOS to change the new RAM sticks to the 3200 mhz. Saving and exiting the BIOS the computer shut down, booted up, then shut down again and booted up once more and stayed on. After messing with the RAM sticks, it was unable to apply the XMP profile of 3200mhz and start up properly, it had to shut down and revert back to the default speed. As a test a placed both new and old RAM stick in independently and they ran at 3200mhz without failure, but when they are put in all 4 together, they do not work at 3200mhz.
I was able to get it to run on the 2733mhz option, but nothing above that. My BIOS is up to date.
If anyone can help it would be much appreciated.
https://linustechtips.com/topic/1276723-ram-speed-issues/
What CPU?
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
https://linustechtips.com/topic/1276723-ram-speed-issues/#findComment-14269384
Running 4 dimms at high speeds is very hard on the IMC. Additionally, the motherboard's QVL does not have any 4 dimm 3200Mhz kits listed as supported at full speed. The fastest 4 dimm kit on the QVL with your CPU is 2933Mhz.
You might be able to raise your SOC voltage to 1.1V-1.2V to get it stable. But keep your expectations in line with the above.
https://www.msi.com/Motherboard/support/B450-TOMAHAWK-MAX#support-mem-18
BigBox (HTPC):
  • Display: None
  • 2.5Gb NIC
NAS:
  • Synology DS216J
https://linustechtips.com/topic/1276723-ram-speed-issues/#findComment-14269403
Sorry to threadjack, but I quite literally upgraded my RAM today by adding two additional RAM sticks of Corsair Vengeance CMW16GX4M2C3600C18 and I'm also having BSOD issues (PAGE_FAULT_IN_NONPAGED_AREA). Could it be the same issue for me?
Motherboard: MSI X570 A-Pro
CPU: Ryzen 7 3800X
RAM: 4x 8GB Corsair Vengeance 3600 C18 CMW16GX4M2C3600C18
And if that's the case, the logical assumption is that going to two sticks of 16 GB each could solve that issue, is that correct?
I like cute animal pics.
Ryzen 7 5800X3D + RTX 5080 | see profile for full system details
https://linustechtips.com/topic/1276723-ram-speed-issues/#findComment-14270004
CPU: Ryzen 7 3800X
The 3800X does not have quite the same restrictions as the 3400G, since it has a better IMC. But yes, this could still be a similar issue, and the same solution may help you.
You should start your own thread if you need further assistance.
BigBox (HTPC):
  • Display: None
  • 2.5Gb NIC
NAS:
  • Synology DS216J
https://linustechtips.com/topic/1276723-ram-speed-issues/#findComment-14270008
