I just installed a new graphics card and now my pc is making a deep hum that you can feel in the floor and above on my desk. (Pc is on floor). I made sure it wasn’t the graphics card by turning the fans off on it then I located the source I think. A hard drive. I am super confused because there is no rattling or a strong source of vibration from the drive but when I boot without the drive it does not make a low hum. I am just confused at this point.
https://linustechtips.com/topic/1276465-low-deep-hum-from-pc/
Yeah, that's a HDD for you.
The drive doesn't make a noise on its own, but its spinning disks are causing a vibration.
Sometimes this vibration is actually amplified by the system its self.
You need to try to isolate the HDD with rubber washers, or something similar to resolve this.
Its very common to hear the HDD's, especially if the rest of the system is fairly quiet.
Do what you can to isolate the drives vibrations from the case mounts.
Maybe when you were adding the new GPU you bumped the drive causing it to rest against the case now where it wasn't before?
Maybe you didn't notice it before because your old GPU was too loud in regards to its own fan noise?
And if you suspect this noise has increased, you might run some diags on the drive if the manufacture has any.
I only use SSD's now in my main system but if im in the room where my unraid box is, with HDD's on it, i can hear them plain as day.
Clicking and humming away.
Daily driver (looking to upgrade mobo and cpu spring of 2021)   --- The only time I sort by price from high to low is when I am shopping for CPU's and GPU's (looking for a cheap i7-7700k though)
Mobo: ASRock Z170 Extreme7+  CPU: i7-6700K @ 4.6MHz OC  Cooling: Corsair H115i Hydro  Memory: TridentZ 32GB @ 3600MHz  GPU: EVGA 2070 FTW3 ULTRA+ (OC'd 50/300)
PSU: Corsair HX850i   Storage: 980 Pro 1TB, 950 PRO 512Mb, (2)ADATA SU800 1TB  Keyboard: Logitech G910  Mouse: Logitech G502   Headset: Logitech G930 UPS: APC Pro 1500 S
Unraid box providing network routing, home automation services, and media services ( I love unraid!)
USB Key: SanDisk 16GB Ultra Fit  Mobo: Intel DX79SR Extreme+  CPU: i7-3820  Memory: 16Gb Kingston HyperX Predator  Storage: (cache)480gb Micron SSD (1)8TB HDD (1) 4TB HDD
GPU: MSI GTX 1650 4GT LP OC (passed through to Emby)  NIC: Intel I350-T4 4-port Gb (passed through to PFSense)  UPS: APC PRO 1000
Docker Containers: Emby and Home-Assistant-Core  Virtual machines: PFsense ( I love PFSense!)
Family machines
Mobo: Asus Prime H310M-E  CPU: Intel Core i3-9100F  Cooling: Deepcool Gammaxx 400  Memory: Teamgroup Elite Plus DDR4 16GB  Storage: Silicon Power 1TB NVMe M.2
GPU: Asus GTX 1660 Super 6GB or EVGA 1070 FTW 8GB  PSU: Thermaltake Smart 500W 80+  UPS: APC XS 1300
As well as a number of other machines, a ton of parts, miles of cables, and who knows what else!
Private message me for quicker assistance. I also build and ship custom machines at a really fair price.
https://linustechtips.com/topic/1276465-low-deep-hum-from-pc/#findComment-14269371
