240hz overwatch help needed
Go to solution Solved by Moonzy,
4 minutes ago, c0d0ps said:
Would 5600x help more or is 6 cores not enough upgrade to be worth it? I was thinking of getting 8 cores but idk if 3700x or 5800x.
I do new nvenc streaming.
if overwatch, 5600x is more than enough
but if u wanna ensure a good experience while streaming, 5800x is a good choice for extra headroom
the cores of 7700k isnt that strong, compared to cores nowadays
I currently have an i7 7700 at 4.2k ghz with 3000 mhz ram and a 3070 and I have some trouble getting stable 220 fps and above. Do I need to upgrade my ram/cpu or just get a new cpu cooler to oc it?
and yes I know the cpu is old but it's ow :D
PC  Specs 2022:
  • CPU
    AMD Ryzen R9 5900x @ 5.1GHz - Auto OC
  • Curve Optimizer Magnitude: -20
  • Motherboard
    ASUS ROG STRIX x570-F Gaming
  • RAM
                                        Kingston Fury 32GB DDR4 3200MHz 16x2GB
  • GPU
    MSI 3070 8GB Ventus 2x OC
  • Case
    LIAN LI LANCOOL MESH II Mesh RGB Black
  • Storage
    Kingston NV1 2TB M.2. NVMe
  • PSU
    Seasonic Focus GX 850w
  • Display(s)
    MSI OPTIX MAG 251RX IPS 240hz & ASUS MG248Q Vertical 144hz & Dell 60hz
  • Cooling
    NZXT Kraken x73 360mm
  • Keyboard
    Tt eSports Meka G1
  • Mouse
    Logitech G Pro Wireless
  • Operating System
    -Windows 10 Professional 64bit
https://linustechtips.com/topic/1276132-240hz-overwatch-help-needed/
Well if usage of both should tell that story. Doubt an oc will do anything as it rarely does for real world scenarios on that regard.
But I’m sure someone can post a YouTube video of that same setup doing 300 frames without an issue as they usually do.
Monitor the usage of both CPU and GPU
If GPU is pinned at 99%, maybe turn down settings
If CPU is constantly above 80% in one thread, whole gpu isn't pinned at 99%, then it's probably CPU limited and you'll need a CPU upgrade if you want more than 220 fps
Being CPU limited can cause frame pacing issues too, so it's undesirable esp if you're competitive
-sigh- feeling like I'm being too negative lately
I don't think any of them is pinned at 99 because I play on lowest settings and 75% render scale for best fps.
PC  Specs 2022:
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Tt eSports Meka G1
  • Mouse
  • Operating System
cpu seldom pins at 99%, as long as a single thread is consistently above ~80%, and gpu isnt at above 95%, it's most likely a cpu bottleneck
or game is badly optimised
cpu is at 60% and gpu is at 50% cpu core 1 is around 70%
bottle neck means I need to oc more? I thought the i7 7700k could handle all gpus but tbf I don't oc much with my 212 evo.
PC  Specs 2022:
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Tt eSports Meka G1
  • Mouse
  • Operating System
7700k is aging a bit, tbh
PC  Specs 2022:
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Tt eSports Meka G1
  • Mouse
  • Operating System
Is this a good deal?
i9 9900k, corsair hydro H100x, asus strix z390, corsair 2x8gb ram at 3200 mhz cl 16
for 800 euros? a pc store is selling that upgrade bundle seems like I save 60 euros
Maybe ryzen is cheaper/better not sure.
PC  Specs 2022:
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Tt eSports Meka G1
  • Mouse
  • Operating System
you can make a new thread in new builds and planning subforum, people might be able to come up with a better build for your money
im not familiar with pc pricing nowadays, heh
