Budget (including currency): ~1000
Country: US
Games, programs or workloads that it will be used for: CS, GTA etc
I was thinking that this was pretty good. Would be upgrading from and i5 + 1060 6gb. Just gonna re-use old ram and storage stuff. Any suggestions? Also the 5700xt I had been looking at got bought so I just put in the suggest PC Partpicker one. Anyone know where I can get one now thats not gouged or am I just going to have to wait? Thanks in advance
https://linustechtips.com/topic/1275502-new-build-please-help/
Country: US
1. Go with ryzen, better bang your buck
2. You don’t have a PSU
3. That case has bad airflow, put a new o e
4. Stock is horrible this week, wait about 1 - 2 weeks and then try to build another list, normally 5700xts can be found for under 390 but not today
geometry is hard
b550 > x570
https://linustechtips.com/topic/1275502-new-build-please-help/#findComment-14260080
On another note that i7 is outdated and it's a much better idea to either get the better new ryzens or the i5 10600 to avoid being stuck on a 8core/8thread cpu.
All the other points especially the case are solid
https://linustechtips.com/topic/1275502-new-build-please-help/#findComment-14260087
Which Ryzen do you think and what mobo? I have a PSU just forgot to mention I was re-using that too. Any case suggestions? My main goal is going to be running 1440p @ 144hz so is the 5700xt going to be up for that? If not what GPU and any idea who's gonna have stock on it?
https://linustechtips.com/topic/1275502-new-build-please-help/#findComment-14260088
Ryzen isn't really better bang for buck, it's better future upgrade-ability. The 8th and 9th gen intel cpu's are pretty cheap compared to ryzen. If he gets a cheaper z390 motherboar he'll be saving money compared to a 3700X and a b450 Tomahawk.
https://linustechtips.com/topic/1275502-new-build-please-help/#findComment-14260089
1 hour ago, WikiForce said:
people still recommend 1st or 2nd gen ryzen so i think 9th gen i7 is fine too, it has decent ipc and 6c/12t is pretty much the sweet spot for gaming nowadays
The 9700k is an 8 core no ht hence why I don't recommend it. I am looking at the future aka 2 years forward to when the ps5 and xbox x are the main consoles and you know devs are not gonna super optimize their games to run on stuff below 16 threads well
https://linustechtips.com/topic/1275502-new-build-please-help/#findComment-14260551
