Budget (including currency): 300 Kd
Country: Kuwait
Games, programs or workloads that it will be used for: Blender, Fortnite, Unreal engine(basic not very complex work loads)
Other details: This is a complete build from scratch and it is my first build so I wanted to know whether the following components are the best for the price And I also wanted to know which power supply I should use if I wanted to overclock the cpu in the future when I buy a cpu cooler, but for right now I am not overclocking and using the cooler that comes with it. Thank you.
https://linustechtips.com/topic/1272907-first-build/
LIst it here: https://pcpartpicker.com/
Whats your budget? Have you already got the parts?
https://linustechtips.com/topic/1272907-first-build/#findComment-14240467
