Budget (including currency): 1900€-2600€
Country: Germany
Games, programs or workloads that it will be used for: Flight Simulator, Minecraft, Rocket League
Other details Im planning to build my first PC. I wanna play games at 1080p and 144hz. Im afraid if these parts dont work together.
Parts:
CPU: Ryzen 5 5600x
GPU: Gigabyte Rtx 3070 Master
Cooler: Corsair H100i RGB PLATINUM
MB: Asus ROG Strix X570-F Gaming ATX AM4
RAM: Corsair Venegance RGB Pro 32GB (4x8GB) DDR4-3200 CL16
SSD: Samsung 860QVO 2TB 2.5"
Case: Corsair 275R Airflow ATX Mid Tower Case
Power Supply: Corsair RMx (2018) 750w 80+ Gold Fully Modular ATX
Case Fans: 4x Corsair LL120 43.25 CFM 120mm (Water cooler on the 2 up fan places in the front, all fans pulling air, only the 1 on the back doing the exhaust)
Extra: Corsair Commander Controller to put all the fans connected
PS: Sorry if i wrote something wrong, bcs of my english
https://linustechtips.com/topic/1271732-help-with-compatibility/
pcpartpicker.com, although may not be a good website to use to order the parts (internationally outside of the US, that is; ) I would "build" the pc on the website, as it will show you the part compatibility.
Side note; your English is Excellent
@timmylgl
@timmylgl
when i put on pcpartpicker it says that the Mother Board may not have compatibility with the CPU bcs of the new zen3 it can require a BIOS update. Do you know if asus already has the updated bios for 5000 series? @TangoJKilo
according to ROG's website yes, it supports 5000 series.
