DOOM Eternal stutter with a CPU swap
Solved by polski8bit,
27 minutes ago, Zando Bob said:Have you installed AMD's chipset drivers? Usually Ryzen CPUs/mobos need those to behave properly. Assuming that's a single 8GB DIMM it'll hurt performance for your chip, but it shouldn't cause stutters like that AFAIK.
Considering the fact that it works properly in other games, I don't think that's the case. Thanks for the reply tho.
I actually found the solution on Steam forums that is really dumb. If anyone else will have that sort of problem, in my case turning off "Present From Compute" option in Video settings fixed the issue.
