Hi all. I have a question please
I have the following PC:
  • Ryzen 5 3600 (Wraith Prism cooler)
  • B450 Steel Legend board
  • 16gb RAM (2 x 8gb)
  • 1TB Samsung 970 NVME
  • 1TB HDD
  • GTX 1050ti
  • Corsair VS550w PSU
  • 144hz 1440p monitor
I dont really do any overclocking, aside from using MSI afterburner and having XMP enabled.
I'm looking to upgrade the GPU to something a bit more substantial for 144hz 1440p gaming but I'm trying to avoid changing the PSU (I've not had it that long).
May I ask whats the highest I could go on the GPU without having the Fire Brigade on standby?
Thanks all :)
https://linustechtips.com/topic/1270271-max-gpu-for-my-psu/
I use a 500W PSU with a 1660 Ti (You can see my Signature for My specs) And I dont have any issues with power. I agree with @GoodEnoughOn that
My Specs:
CPU: AMD Ryzen 5 3600 3.6 GHz (OC to 4.45GHz)
Graphics Card: Nvidia GeForce GTX 1660 Ti
RAM: G.Skill Ripjaws V DDR4 3200
Motherboard: ASRock X570 Phantom Gaming 4S
Storage Device: 2X 1TB WD Blue HDD, 256GB Samsung 970 EVO Plus (Windows install)
Case: NZXT H510i
Keyboard: Corsair K70 TKL Champion Edition/Reddragon K552 (Blue Switches)
Mouse: Glorious Model O
Headset: Corsair H60 Pro Surround
https://linustechtips.com/topic/1270271-max-gpu-for-my-psu/#findComment-14220711
1 minute ago, Bassai Dai said:
Oh I see. I was kinda looking at a 2060 ish?
Thats possible, Do you have a PcPartPicker Link for this build?
Edited by Jplayz
Misspelled
My Specs:
Case: NZXT H510i
https://linustechtips.com/topic/1270271-max-gpu-for-my-psu/#findComment-14220722
From What I see on PC Part Picker, the max you can do is a NVIDIA GeForce RTX 3080 10 GB Founders Edition
My Specs:
Case: NZXT H510i
https://linustechtips.com/topic/1270271-max-gpu-for-my-psu/#findComment-14220743
Yeah it's here:
That list has no GPU though
https://linustechtips.com/topic/1270271-max-gpu-for-my-psu/#findComment-14220764
Just now, Bassai Dai said:
Thank you and I have double checked, the Max Card you can put on a 550W PSU is a NVIDIA GeForce 3080 Founders Edition 10 GB, heres an edited list:
My Specs:
Case: NZXT H510i
https://linustechtips.com/topic/1270271-max-gpu-for-my-psu/#findComment-14220774
Thanks, although that's a little less headroom than i'd be comfortable with.
Nice to know that I could perhaps go up to the 2060/3070 though
https://linustechtips.com/topic/1270271-max-gpu-for-my-psu/#findComment-14220787
Yeah, I forgot to mention that, There isnt a lot of headroom with that card
My Specs:
Case: NZXT H510i
https://linustechtips.com/topic/1270271-max-gpu-for-my-psu/#findComment-14220806
No problem.
I'm thinking my R5 3600 will keep up with a 2060 no issues
Yeah, I wouldnt think that would be a issue, but maybe going up to 3000 Series might bottleneck it
My Specs:
Case: NZXT H510i
https://linustechtips.com/topic/1270271-max-gpu-for-my-psu/#findComment-14220816
