Use a big beefy air cooler such as the Noctua NH-D15 or be Quiet! Dark Rock Pro 4 to keep temperatures down. They are pretty comparable to AIOs on the market today.
I personally prefer air cooling over water cooler b/c electronics and water don't mix and when AIOs fail either by leakage (very slim chances of this occurring, but can happen) or pump failure (the most probably cause of AIO failure) you can suffer from water damage or high CPU temperatures respectively.
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
https://linustechtips.com/topic/1269933-liquid-vs-air-cooling/#findComment-14218197
LTT did a video on this. A quality air cooler from a company such as Noctua can handily outperform a AIO in both cooling and noise levels. From my experience with my AIO, before I went crazy with the fans, I was shocked at how quiet it was (I had a laptop before and that thing sounded like a jet engine) And I really liked my temps.
PC specs:
Ryzen 9 3900X overclocked to 4.3-4.4 GHz
Corsair H100i platinum
32 GB Trident Z RGB 3200 MHz 14-14-14-34
RTX 2060
MSI MPG X570 Gaming Edge wifi
NZXT H510
Samsung 860 EVO 500GB
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Razer Deathadder 2013
Logitech G935 Wireless
https://linustechtips.com/topic/1269933-liquid-vs-air-cooling/#findComment-14218215
Liquid is vastly superior.
So it comes down to what you mean by liquid cooling. As they tend to be grouped together for some reason.
Also case and fans are another large factor. The gpu cooling will also effect everything.
https://linustechtips.com/topic/1269933-liquid-vs-air-cooling/#findComment-14218871
