hi guys i have hard time deciding what tv i should buy so i come here to ask your opinion.
the models i consider to buy (you can suggest others but im not from US so we dont have have the same models) : Samsung TU - 7000/7100/8000/8500, Hisense - U7QF/U8QF, Sony - XH9096 i think this the same as XH9005 but sony is kinda expensive for me. the most important thing for me is quality and reliability.
https://linustechtips.com/topic/1269695-help-choosing-tv/
yea both of those sony's are h90's 2020 releases and best tvs in that list
the hisense are also 2020 models but better then the samsungs the u8qf is the best of the hisense
those samsungs are entry level older tvs 2018 and older.... best is the 8500 but sony and hisense are 2020 tvs and have better picture and options
brand also you can look at is LG, their oled (might be pricey) or the nano90 (only hickup is it doesnt have perfect black, so in a room with no light blacks are really dark grey but if you have a light on, doesnt have to be bright, looks normal black) tv is a ips panel is why not perfect black. but picture is gorgeous
https://linustechtips.com/topic/1269695-help-choosing-tv/#findComment-14216249
from what i read samsung TU is 2020 models. i already have LG UM7340 not realy like it, very blury not so good in day light like people say  not and gray colors so i want try VA panel now
https://linustechtips.com/topic/1269695-help-choosing-tv/#findComment-14216332
shit your right TU is 2020. but still looking at rtings ... they are "ok". and budget tvs...the hisense and sony still have better screens and features
if your looking at samsungs look at the q60, q70, q80, q90. oh course the higher the number the better it is
LG UM7340 was never a good tv. thats lgs entry level
if you have a lot a light in your room then yea you want to go led...ips and oled dont do good in "bright" rooms
https://linustechtips.com/topic/1269695-help-choosing-tv/#findComment-14217556
