i am not really understand about pc, and i am a casual gamer, and i dont upgrade my pc since 2014, except the gpu
my gpu was gtx 1050 ti no power pin, it died after 4 years, died too fast
not sure what killed it, it spinned but didnt display, tested in friend's pc same
when i bought the gpu, the shop owner offered me a psu,
the psu is gamemax gp 550w 80 plus bronze
i bought it
no issue in 4 years, only 10 times my pc auto shutted down in 4 years, maybe cables issue caused it auto shutted down, because i saw it once, ripped psu cables made auto shutted down
no freeze, no crash, no blue screen and else
but i noticed the other thing,  one sata cable has 3 branch satas, i plugged my old hard drive to the second sata branch cable from psu, it made noise, it was like it tried to spin but fail, and the hard drive crashed, then i plugged to first sata branch cable, it worked normally
oh, my whole pc is : i7 3770, 16gb ram 1.5v ddr3 , 5 120mm fans , one ssd, one hdd, 550w psu i mentioned above
and gtx 1050 ti no power pin before it died
does my psu kill my gpu? or unknown issue?
but the psu still works well
thank you
https://linustechtips.com/topic/1268588-psu-and-pc-components/
10 minutes ago, Rooked said:
Yes your PSU possibly killed your GPU. Bad PSU's can kill computer parts and considering it isn't even in the PSU list:
You should replace it with either a Tier B or Tier C PSU. I recommend the Corsair CX gray series (gray labels not green).
i agree to replace it, but it worked well for 4 years? is it still psu problem?
https://linustechtips.com/topic/1268588-psu-and-pc-components/#findComment-14207447
working, doesnt mean its doing well.
this is a suspect for what killed the GPU after 4 years.
Could you take internal pictures of this?
https://linustechtips.com/topic/1268588-psu-and-pc-components/#findComment-14207776
could have been the psu, gpu or the pci e slot in the mobo that caused it. Can you test the pc with other gpu to make sure the mobo is working? It probably is working but I hate the wheeling when you buy a new part when you thought that was the issue, but it was not.
Also the psu is a suspect too.
the gpu could have died for too much overheating
pics of the psu?
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1268588-psu-and-pc-components/#findComment-14207785
3 hours ago, Rooked said:
If your GPU died just like that, it's likely your PSU.
ok, i will go with tier B
the psu is covered by pc case, i need to unplug every cable to drag it out
my psu name is : gamemax gp-550 550 watt 80 plus bronze
pics of the psu?
i tested everything, ram, cpu can display, and some random old gpus also can display, pcie slot is good
https://linustechtips.com/topic/1268588-psu-and-pc-components/#findComment-14207923
Pretty bad, but should not kill such low power gpu.
https://linustechtips.com/topic/1268588-psu-and-pc-components/#findComment-14207936
um...... its a 1050ti, probably not. fan would have to die and the powerthrottling would stop that from happening. and he would notice that very easily.
how would a 12v, or similar to core happen with a GPU that isnt being inserted often.
given its a group regulated unit, doesnt really matter if its high power or not..........
https://linustechtips.com/topic/1268588-psu-and-pc-components/#findComment-14207947
