it seems like kde plasma is having weird glitches with running in vmware (kubuntu having weird ribbon glitches, opensuse leap shell crashes, etc.) is there something wrong with vmware that causes it to have issues with kde plasma 5? if so, is there an easy fix?
some chill gamer
setup:
core i7 9700f
16gb 2666mhz ram (dual channel)
512gb sandisk sata boot ssd i salvaged from my broken laptop (lenovo doesn't seem to have great quality ideapad laptops)
480gb sata ssd that came with my system
2tb hdd
msi geforce rtx 2060 super
asrock b365m ib-r mobo
logitech g513 rgb keyboard
logitech m720 triathlon wireless mouse
logitech g935 wireless rgb headset
fifine k669b usb mic
some old samsung 1080p60hz monitor (upgrading it soon)
some cheap "rgb" mousepad i got for christmas
and the most important part, real rgb inside the case
The easy fix is to switch to Virtualbox.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
vmware seems to be better for my needs
some chill gamer
setup:
core i7 9700f
2tb hdd
1 minute ago, Yummychickenblue said:
Are you running Plasma under Xorg or Wayland?
it's the default environment when installed with kde, the sddm screen says it's using plasma, and i can select between icewm session, plasma, twm, plasma (full wayland), and plasma (wayland)
some chill gamer
setup:
core i7 9700f
2tb hdd
Is there ane behaviour difference when using Plasma, Plasma (full wayland), and Plasma (wayland)?
I had this same experience a few years back with Plasma X11. I haven't run Linux in a virtual machine for the past year now, so I can't say what things are like right now, but VMWare Workstation had better OpenGL performance than VirtualBox (I vaguely remember LLVMpipe plaguing me back then).
haven't tried that, but probably will now
some chill gamer
setup:
core i7 9700f
2tb hdd
the wayland versions seem to not crash kwin as much, but might be a bit glitchier in some ways. the cursor in full wayland is slightly drifted but enough to drive you crazy, and won't change.
assuming that normal plasma is running on xorg, xorg seems to crash more, but wayland seems to have some bugs.
some chill gamer
setup:
core i7 9700f
2tb hdd
