Computer will not post help please!
Go to solution Solved by cr8tor,
Well with what you describe i really suspect the power supply.
But you should reseat things and strip it down to bare components to narrow the possibilities as much as possible.
Definitely check the power cable to the GPU also.
i built my computer and it worked fine for a few days then it just died and would not post before it died it restarted several times that day. Now it has a orange vga light. I really need help. Thanks!
specs:
Case- NZXT H1
Motherboard- Asus Rog Strix b450-i mini itx
cpu - Rhyzen 7 8 core
Ram- Corsair Vengeance lpx 3200mhz
Gpu- RX 580 Armour 8gb OC
ssd- samsung 970 evo 500gb or 1tb
https://linustechtips.com/topic/1267434-computer-will-not-post-help-please/
What power supply do you have?
And a pic of the inside of the case would be much more useful than the front. 🙂
Daily driver (looking to upgrade mobo and cpu spring of 2021)   --- The only time I sort by price from high to low is when I am shopping for CPU's and GPU's (looking for a cheap i7-7700k though)
Mobo: ASRock Z170 Extreme7+  CPU: i7-6700K @ 4.6MHz OC  Cooling: Corsair H115i Hydro  Memory: TridentZ 32GB @ 3600MHz  GPU: EVGA 2070 FTW3 ULTRA+ (OC'd 50/300)
PSU: Corsair HX850i   Storage: 980 Pro 1TB, 950 PRO 512Mb, (2)ADATA SU800 1TB  Keyboard: Logitech G910  Mouse: Logitech G502   Headset: Logitech G930 UPS: APC Pro 1500 S
Unraid box providing network routing, home automation services, and media services ( I love unraid!)
USB Key: SanDisk 16GB Ultra Fit  Mobo: Intel DX79SR Extreme+  CPU: i7-3820  Memory: 16Gb Kingston HyperX Predator  Storage: (cache)480gb Micron SSD (1)8TB HDD (1) 4TB HDD
GPU: MSI GTX 1650 4GT LP OC (passed through to Emby)  NIC: Intel I350-T4 4-port Gb (passed through to PFSense)  UPS: APC PRO 1000
Docker Containers: Emby and Home-Assistant-Core  Virtual machines: PFsense ( I love PFSense!)
Family machines
Mobo: Asus Prime H310M-E  CPU: Intel Core i3-9100F  Cooling: Deepcool Gammaxx 400  Memory: Teamgroup Elite Plus DDR4 16GB  Storage: Silicon Power 1TB NVMe M.2
GPU: Asus GTX 1660 Super 6GB or EVGA 1070 FTW 8GB  PSU: Thermaltake Smart 500W 80+  UPS: APC XS 1300
As well as a number of other machines, a ton of parts, miles of cables, and who knows what else!
Private message me for quicker assistance. I also build and ship custom machines at a really fair price.
It comes with a psu and a water cooler here is a picture of what its called. Also im not near the pc at the moment
Family machines
I get the same error i made sure everything was plugged in
