Memory upgrade help!!!
Solved by Skiiwee29,
Get the cheapest you can. According to PcPartpicker, these are the cheapest: https://pcpartpicker.com/product/hwPKHx/team-elite-plus-16gb-2-x-8gb-ddr4-2400-memory-tprd416g2400hc16dc01
Here is the full list of 2x8 kits at 2400mhz speed on PcPartpicker. There is a whole host of them in the 50$ range as those are so you can pick what you want.
https://pcpartpicker.com/products/memory/#Z=16384002&S=2400&sort=price&page=1
