Hi, i'm Harrison, aged 17
This was my first build, I spent ages researching my components and their price/performance ratio's. I think I found a great balance.
SPECS:
AMD FX-8350
AMD VTX3D Radeon 6970
4gb generic RAM from my previous PC
Intel 520 120gb SSD
Thermaltake TR-2 800watt PSU
Corsair 600t Black
Pictures Below, please give some feedback. Thanks alot guys!
post-17729-0-69662100-1367510470_thumb.j
post-17729-0-04327400-1367510481_thumb.j
post-17729-0-83399000-1367510492_thumb.j
post-17729-0-69563300-1367510504_thumb.j
post-17729-0-67044100-1367510515_thumb.j
post-17729-0-31523500-1367510524_thumb.j
post-17729-0-76347700-1367510535_thumb.j
post-17729-0-31208600-1367510549_thumb.j
post-17729-0-95707400-1367512870_thumb.j
post-17729-0-58684000-1367512943_thumb.j
post-17729-0-66508500-1367512984_thumb.j
post-17729-0-58050600-1367513019_thumb.j
My Build:
CPU: AMD FX-8350 @ 4.3Ghz GPU: vtx3d AMD radeon 6970 RAM: Crap $2 4gb memory lol
Mobo: ASUS Sabertooth 990fx r2.0 gen 3 PSU: Thermaltake TR-2 800 watt Case: Corsair 600t Black I'm here to help  :D
https://linustechtips.com/topic/12669-rate-my-first-build/
not bad for your first build, id sleeve the cables {its pretty cheap but it makes it look cleaner}
X79A GD65 (8D), 3820, 7770, 16GB (1600Mhz cas9), 850watt(ocz zx), storm trooper, h100, xonar xense, sp2500, pc350, asus PA248Q LG 22'' ips, razor black-widow ultimate 2013, 120GB intel 520 series 128GB crucial M4 2*3TB barracuda 2*1TB barracuda 2TB Hitachi
https://linustechtips.com/topic/12669-rate-my-first-build/#findComment-134876
Decent looking first build. Sort of ghetto mounted SSD, I like haha. I would change the CPU cooler to a Hyper 212 Evo if possible and upgrade to 8 Gigs of Corsair Vengeance RAM(quite cheap these days). Don't like the super bright red PCB on the 6970 :p Other then the above mentioned you're good.
Join the LinusTechTips Star Citizen Org :D ~ https://robertsspaceindustries.com/orgs/UOLTT
https://linustechtips.com/topic/12669-rate-my-first-build/#findComment-134878
Decent looking first build. Sort of ghetto mounted SSD, I like haha. I would change the CPU cooler to a Hyper 212 Evo if possible and upgrade to 8 Gigs of Corsair Vengeance RAM(quite cheap these days). Don't like the super bright red PCB on the 6970 :P Other then the above mentioned you're good.
Thanks :) aha yeah the 6970 is extremely ugly :P . Thanks for the parts suggestions i'll look into them  :rolleyes:
My Build:
https://linustechtips.com/topic/12669-rate-my-first-build/#findComment-134891
Not bad for your first build.Like oisin I'd recommend sleeving your cables. It also makes you fell more proud of what you've done :)
Thanks for the feedback, can you give me some tips on how i'd go about sleeving them? I'll google around but some tips would be appreciated. Thanks again  :rolleyes:
My Build:
https://linustechtips.com/topic/12669-rate-my-first-build/#findComment-134902
OK so now I'm officially jealous of your case..I've been trying to get my hands on an Obsidian 600D and up case for 3 years but it's too pricy for a case imo. I'm thinking of upgrading my RAM from 4GB to 8GB at least as I tend to do a bit of rendering of gaming videos, and other generic and other related type of videos I randomly upload to my YouTube channel. I do however like the overall setup you have there. My current PC is actually my first gaming PC build, which is the one I'm currently using. For an album of photos of my PC check here.
https://linustechtips.com/topic/12669-rate-my-first-build/#findComment-134912
Yes, the 600t is sexy  :P and it was only $180 (Australian dollars) Your setup looks awesome especially the blue LED strips, mind sharing where you got them?  :D Just work on your cable management a bit. What's your YouTube channel? i'll check it out.
My Build:
https://linustechtips.com/topic/12669-rate-my-first-build/#findComment-134974
Oh and maybe if you needed to, add a WD Blue 1TB.
Yeah i've only 19gb left on my drive  :unsure: I'm trying to keep my storage all super fast though so it's my plan to get another SSD.
My Build:
https://linustechtips.com/topic/12669-rate-my-first-build/#findComment-134980
Looks really neat nice work, ;)
Your first build looks far more awesome than my first one did! Was nervous as hell building it so that could have attributed! Keep up the great work, man. The younger populous are so smart now adays! Or, at least those in this forum. :)
the mix mash of red dark green and blue makes me smile :D
Thanks heaps guys for the nice feedback  :D
My Build:
https://linustechtips.com/topic/12669-rate-my-first-build/#findComment-134992
Here is a link for sleeving: http://www.overclock.net/t/1262904/video-sleeving-guide-series
Also, very clean build. Nice work.
Gigabyte GA-X58A-UD3R (Rev. 2.0)    Micron C400 256GB SSD     MSI GTX 660 Ti PE OC     Logitech G510
Intel i7 960 @ 4.125GHz                        WD Black 1TB                         Windows 7 Pro 64bit        Logitech G9x
Kingston HyperX 6GB                             Corsair TX850M                     Corsair H50                        Logitech z906
https://linustechtips.com/topic/12669-rate-my-first-build/#findComment-135123
^This, but very good for your first build :)
https://linustechtips.com/topic/12669-rate-my-first-build/#findComment-135853
overall very good first build. better than mine first build. BIG creds for motherboard and CPU!!!  :D
Intel Core i7-3770K @ 4.9GHz |--| Gigabyte Z77X-UP7 |--| 16GB Crucial BalisitX Elite @ 1600MHz |--| Sapphire + Gigabyte HD 7990 in Quad CrossfireX @ 1,100MHz |--| Samsung 840 Series 250GB SSD |--|  2x Seagate Momentus XT 750 GB HDDs in Raid0 |--| CoolerMaster V1200 Platinum |--| Corsair Obsidian 750D
"There is no heaven or afterlife for broken-down computers; that is a fairy story for people afraid of the dark." - Stephen Hawking
https://linustechtips.com/topic/12669-rate-my-first-build/#findComment-137314
Nice build, the 6970 is still a great card to use, I would however, get rid of that god awful stock cooler.
Come and join the awesome Official LTT Star Citizen Org at LTT Conglomerat,  GTA 5 LTT Crew at LTT Conglomarate
PC Specs - 4770k - OC 4.5GHz  - GTX 780 SC - 16GB HyperX - NZXT H440 White - Corsair H100i - Corsair AX750 - Samsung Evo 250GB - 2 x PA238Q - ATH-M50 -
https://linustechtips.com/topic/12669-rate-my-first-build/#findComment-137403
