Cooling for new build
Solved by narrdarr,
In term of cooling you should not get that case. It lacks sufficient airflow for a build like yours.
You should be looking at
P300a
P400a
P500a
Lancool 2 mesh performance
Td500
Meshify c
Or similar
As for a coolers
Air:
Dark rock 4 pro
Nh d15
Nh d14
SilverArrow SB-E Extreme
Assassin 3
Liquid:
Artic liquid freezer II 360
Ek aio 360
Alpha cool 420 aio
For the gpu.
we will need more info on how well the aib coolers are and how well they scale compared to liquid cooling after reviews start coming out.
