Hi,
I'm having a weird issue with overclocking my cpu and memory.
I've been trying to overclock my cpu in bios but after I hit save and reboot, pc won't post and cycle 2-3 times and then just boot up with default settings, the thing is I'm not dialing in some crazy overclock it does this even when I try like 3.3Ghz, or If I load Xmp profile for my ram, I've tried overclocking in ryzen master software and I've been able to hit 3.8ghz at 1.3625V without any crashing, the only thing is you have to load up ryzen master software every time you start your pc. I've tried updating the bios but that didn't help either. I will be thankful for any suggestions.
PC spec:
MB: MSI B350 PC MATE
CPU :AMD RYZEN 3 1200
RAM: Crucial 8GB KIT DDR4 2400MHz CL16 Ballistix
GPU: gtx1060 3gb
psu: Corsair VS450
https://linustechtips.com/topic/1265929-need-help-with-overclocking-please/
did you apply voltage settings as well?
Desktop benching:
3 minutes ago, Ivo_Svk said:
yep I even tried 1.4V at 3.3ghz but still nothing
what about loadline calibration? Ryzen Master and the BIOS do not control voltage the same way.
Desktop benching:
