Will 3070 fit?
Go to solution Solved by Fasauceome,
The ventus really isn't that big. It's quite a lot smaller than your strix 980 TI, which I assume is currently in your 200R.
Hi so I ordered MSI GeForce RTX 3070 8GB Ventus 2X OC and I wondered if it will fit in my corsair carbide 200r? Rest of pc specs in description
PC  Specs 2022:
  • CPU
    AMD Ryzen R9 5900x @ 5.1GHz - Auto OC
  • Curve Optimizer Magnitude: -20
  • Motherboard
    ASUS ROG STRIX x570-F Gaming
  • RAM
                                        Kingston Fury 32GB DDR4 3200MHz 16x2GB
  • GPU
    MSI 3070 8GB Ventus 2x OC
  • Case
    LIAN LI LANCOOL MESH II Mesh RGB Black
  • Storage
    Kingston NV1 2TB M.2. NVMe
  • PSU
    Seasonic Focus GX 850w
  • Display(s)
    MSI OPTIX MAG 251RX IPS 240hz & ASUS MG248Q Vertical 144hz & Dell 60hz
  • Cooling
    NZXT Kraken x73 360mm
  • Keyboard
    Tt eSports Meka G1
  • Mouse
    Logitech G Pro Wireless
  • Operating System
    -Windows 10 Professional 64bit
https://linustechtips.com/topic/1265593-will-3070-fit/
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1265593-will-3070-fit/#findComment-14183087
That sounds great. And yes I am currently borrowing my brother's 1070 ti because I was streaming but thanks. Would not expect that to be a smaller card but that's awesome.
Will I need to reduce the power limit in msi afterburner because I only have a Corsair CX 600M? It's probably one of the few things I have not changed since I build the pc 6 years ago. Some things were upgraded though.
PC  Specs 2022:
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Tt eSports Meka G1
  • Mouse
  • Operating System
https://linustechtips.com/topic/1265593-will-3070-fit/#findComment-14188723
600 watts is an adequate amount, but that green label 600M is a pretty low quality unit by today's standards. If the 3070 doesn't run with it, lowering the power limit might not help.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1265593-will-3070-fit/#findComment-14188783
What does about the green label is bad? I don't know much about psus.
I'll try to keep it in mind. Expected delivery is 30 november but who knows if they will delay or not.
PC  Specs 2022:
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Tt eSports Meka G1
  • Mouse
  • Operating System
https://linustechtips.com/topic/1265593-will-3070-fit/#findComment-14188837
it has an older design that leads to poor voltage delivery.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1265593-will-3070-fit/#findComment-14188864
