Everytime I stream LoL or apex my pc just goes to crap like my fps goes to 60 and 45 sometimes even in the 20s and i wanted to know how i could fix this. i have a ryzen 2700X with 16 gigs of ram and a rtx 2070. i feel like this shouldent happen with this hardware if someone could help that would be nice
thank you for your time ❤️
Edited by Chase.N
just had to fix something
https://linustechtips.com/topic/1265266-i-need-help-with-streaming/
What are your stream settings? Are you using GPU encoding?
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
Just now, Chase.N said:
i'm using cpu encoding cuz when i used gpu encoding my stream would stall a lot
You should be GPU encoding if you have a 2070.
SPECS:
bump your ram up to 32gb also make sure all your back ground stuff is not running i have a 2700 with 32gb ram and 2060ko and can stream with no problems but i found playing games and then streaming on top can tax your ram for a single pc setup but im playing COD WZ
ill have to save up some money but thats no prob
