Hello Guys, i am new here.
I got an i3 2120, 8GB DDR3 Ram, and NVidia GTX 1050 ti 4 GB.
I would like to upgrade my CPU, But I'm not sure which one from the i7 category would work on my motherboard. Not sure if i can get at least an i7 2600 - 2600k
 I would really appreciate your help, if somebody is sure and know if this processor is working on my computed I'm buying it right now.
my motherboard model : 0M5DCD (Dell Inc.)
https://linustechtips.com/topic/1264730-cpu-upgrade-help/
If it supports a 2nd gen i3, it supports a second gen i7. What model of PC are you using? Is it a Dell optiplex 770 or something?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1264730-cpu-upgrade-help/#findComment-14176136
With a bios upgrade, it might support Ivy bridge like the i7 3770.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1264730-cpu-upgrade-help/#findComment-14176148
17 minutes ago, bajaritos said:
Ye, Its a dell 390 I think
since it has an H61 chipset, the best CPU you could get is an i7 2600 or 2600K (the 2700K is not technically supported even though it's a second gen chip)
hopefully you can find a good used price.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1264730-cpu-upgrade-help/#findComment-14176841
