setup
ryzen 7 1700
asus crosshair VII hero x470
16gb ddr4 g.skill trident
im planning on upgrading my ram to 32gb
can someone verify if 4 of these sticks will work on my board the support manual isn't clear on it
https://www.amazon.ca/gp/product/B01MTDEYHU/ref=ox_sc_act_title_1?smid=A3DWYIK6Y9EEQB&psc=1
buying 2 sets of the new ram
F4-3200C16D-16GTZR
they are G.SKILLS
https://linustechtips.com/topic/1263580-require-help-for-ram-upgrade/
Sell it and get 2x16gb if you want 3200mhz.
if you add 3200mhz to a 2400mhz set it will run at 2400mhz.
1 minute ago, Brandon Preshyon said:
the ram i currently have are 2400mhz
im upgrading to a set with 3200mhz
that might be a slight issue. the 2400mhz will only go up to that so don't waste your money on faster ram if you can't use its speed. its like buying a 3090 for a toddler. the toddler isn't going to need it
just updated the topic please refresh
mate im buying 2 sets of the 3200mhz im completely replacing the 2400s
Then what's the fuzz?
If you're replacing, you don't need to worry about it.
I suggest getting 2 stick rather than 4 sticks if you want 3200mhz.
Just looked on Asus' QVL list for your motherboard. Looks like good to go. You'll have to use XMP to use 3200mhz, but Asus themselves say it's fine.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
copy the model number use ctrl+f to search page and paste in the model number
its quite hard to buy a 2x16 they are never instock
buy it from another brand.
Be aware that 3200mhz is not natively supported on that CPU, you'll have to OC it.
GTZ vs GTZR is non RGB or RGB. That's all.
Project Hot Box
Oppbevaring
yes im quite aware you don't get 3200mhz just by installing it i have to enable XMP i know that
4 minutes ago, Brandon Preshyon said:
Because there's only 2 sticks of RAM in that kit. If you're doubling, you're looking at 4. Which would be the ones listed as 8x4.
Project Hot Box
Oppbevaring
ah! okay thats where i was getting confuse
so 4 of these sticks should have no issues then
also they shouldn't have any issues with a 1st gen ryzen right
