First thing sorry I didn't know on which section this question belongs, My institute has a website like youtube on which I can see there videos, they also have mobile app but when on my pc I try their website this error shows up, I asked them but they have no idea about solution can someone help? I have windows 10 & Edge but how can I enable secure content playback.
https://linustechtips.com/topic/1263429-system-secured-playback-error/
Do you get the same error using Chrome, or any other browser that uses Chromium?
If you do then it is likely that they are blocking them as unsecure, and the edge browser they state that you need is the now unsupported version that would have been removed with the update to the chromium version.
In chrome it says use latest version of edge, Is there any other secure browser which I can use other than edge?
  • 3 months later...
1 hour ago, Tech para said:
Mihir did you get solution? I am facing same issue...required help
Nope I didn't find solution, The problem I finally came to know was that the new microsoft chromium based edge was a problem.
I tried using app on another device with old edge browser (Not chromium) it worked fine.
Bro, thanks a lot , the trick worked. I just uninstalled the latest version of edge version  88 to factory version 44 and it worked!
