Streamcam issue, odd
Gday all,
So for a while now i've had a streamcam, awesome cam, but than again i don't have much to compare to.
However, i seem to be having one issue. Ever since i bought it, i have had it connected to the pc via an USB switch with a USB-C to A converter.
I can use 1080p at 60fps with it, and had no issues.
Now however, i have no more actual need for the USB switch, so figured i would plug it directly into my USB-C header on the back of the mainboard.
Low and behold, it works . . . sort off. It refuses to run at 60fps.
When opening the logitech cam software, it tells me its not connected on an USB 3 port. but . . . its a 3.2 USB-C port?
Hoping someone can help me understand why my USB-C port seems to be malfunctioning?
Mainboard: MSI X570 Gaming Edge Wifi (yes yes i know, i should have read the reviews)
Other specs:
Ryzen 7 3700X
GTX 1080 (soon . . . . )
2x NVME M.2 drives (pci-e gen 3)
1x 256GB SSD on Sata 1 (dual boot for work purposes, bitlocker's a pita)
750 watt PSU (forgot brand, to lazy too pull open for now)
Peripherals:
1x Iiyama 1440@144hz
1x iiyama 1440@75hz
1x iiyama 1080@75hz
Aten USB 3 switch, which connects:
Streamdeck XL
GoXLR mini
Corsair K57
Corsair Ironclaw (slipstream 2:1)
HyperX quadcast (but only for power purposes, refuses to work via wall brick)
(Arctis pro wireless, but not actually connected, powered via wall brick)
