PiHole Help
Go to solution Solved by Falcon1986,
4 hours ago, TinsellyCone241 said:
What should I do?
Did you save dhcpcd.conf and reboot the RPi for changes to take effect?
What does your dhcpcd.conf look like with regards to static IPs?
and when I set the 10.0.0.254 address as my DNS server, nothing will load.
Why are you setting this as your DNS server? Do you have something at 10.0.0.254? I thought this was the local IP you wanted assigned to the RPi.
Any help would be appreciated!
When I set up my PiHole, I took a different approach to giving the RPi a static IP: In my router, I found the list of connected clients and bound the MAC address of the RPi to a static IP address. So even if the RPi is set to DHCP, the router will always give it the same static IP and what I set as the DNS/gateway/etc. How I see it, if I need to move the RPi to another network, I won’t need to worry about changing any config files to resume normal functioning.
So I have been setting up Pi Hole on a raspberry pi 3. I have been following this tutorial, but when I plug in my pi, it says in part of the startup sequence thing "My IP adress is 192.168 etc followed by the IPv6 address, but my router doesn't use 192.168 format. For example, the router's local IP is 10.0.0.1. I want the local IP of the pi to be 10.0.0.254 because that is a static IP. In pihole, it says 10.0.0.254 is the IP, but in rasbian linux, it says its the 192.168 one. When I try to access the dashboard, it doesn't load, and when I set the 10.0.0.254 address as my DNS server, nothing will load. What should I do? I already changed the file like in that artical where you set the static IP. Any help would be appreciated!
https://linustechtips.com/topic/1263037-pihole-help/
What should I do?
https://linustechtips.com/topic/1263037-pihole-help/#findComment-14162840
I did.
See image here
Don't you have to set the DNS server to the RPI's IP Address? I tried doing that because in the Pi-Hole setup there was an option to change the IP Address, which I did change to the local IP that I wanted (10.0.0.254). I am also unable to SSH into the RPI.
I will try this. This is probably a stupid question, but how do I find the MAC address. For some reason the router won't pick up on the hostname.
Edited by TinsellyCone241
Forgot to include image link
https://linustechtips.com/topic/1263037-pihole-help/#findComment-14163024
Oh, I see what you meant. But only change the DNS server in your router after you get PiHole up and running.
The "headless" setup does everything through SSH. But you'd have to place a blank and extension-less ssh file in the boot directory immediately after SD card creation.
There should be a status section in the router's webUI with the DHCP table of all connected clients.
https://linustechtips.com/topic/1263037-pihole-help/#findComment-14163089
There is, I was wondering how I find the MAC address of the PiHole because the hostname isn't showing properly in the WebUI of the router.
K
I don't really need SSH, I just thought it might help diagnose the issue.
https://linustechtips.com/topic/1263037-pihole-help/#findComment-14163122
