Hey guys I got a PC with specs
I3 8100
8gb Corsair ddr4
GIGABYTE H310 M H
GTX 1050ti
Recently I was playing gta V suddenly my PC turned off and restarted but no display, no signal to keyboard and mouse, also when I tried to use dvd the cpu turns off.
Tried to diagnose at a repair shop
they said motherboard has defects
As it was on warranty I deposited at service center but when I received they didn't replaced instead repaired .
I then assembled and to no avail the problem was sort out. The problem still persists. Please help anyone.
Thank You
https://linustechtips.com/topic/1262895-whats-the-problem/
I3 8100
8gb Corsair ddr4
GIGABYTE H310 M H
GTX 1050ti
Thank You
If there was a hardware failure that was not the motherboard, you would have beeps.
Gotta plug in the little speaker in to the FP header near the case power and reset switch.
Looks like this.
You can look up the post codes below in the drop down in my sig.
Good Luck
https://linustechtips.com/topic/1262895-whats-the-problem/#findComment-14160911
I tried
Looks like this.
Good Luck
I tried with your suggestion used a beep speaker but won't get any beeps
https://linustechtips.com/topic/1262895-whats-the-problem/#findComment-14161273
