wifi card
5 minutes ago, fffkylian said:
hi, does the tplink archer t4e have bluetooth?
A quick Google search mentions nothing about Bluetooth in the specifications.
Looking at the card itself from pictures on Amazon, it doesn’t appear to have a visible USB connector which would be used to wire into your motherboard’s USB header for Bluetooth support.
However, the step up model, T5E, is advertised as having Bluetooth support.
https://linustechtips.com/topic/1262707-wifi-card/#findComment-14158964
thanks, any cheaper ones that have bluetooth?
https://linustechtips.com/topic/1262707-wifi-card/#findComment-14158995
For the same cost of the T4E, there’s this Intel AX200-based PCI-e adapter which gives you support for WiFi 6 (backwards compatible with WiFi 5) and Bluetooth 5.
Keep in mind that you will need to have a free USB header on your motherboard to allow for Bluetooth.
https://linustechtips.com/topic/1262707-wifi-card/#findComment-14159038
