Hello, I recently built my first pc and everything works well except for my front mic input.  When I plug In my mic the only output is static even when my headset mic is muted.  The headset works fine, I have checked other headsets.  I have checked my drivers.  I have replaced my front io.  I don't know what else to do.  Any help is greatly appreciated.
https://linustechtips.com/topic/1262649-front-io-mic-input/
Post your system specs, mainly, what mobo do you have as well as what case.
And have you visually verified the connector is 100% perfect? Many times i have though i plugged in a cable correctly only to discover i had not.
Daily driver (looking to upgrade mobo and cpu spring of 2021)   --- The only time I sort by price from high to low is when I am shopping for CPU's and GPU's (looking for a cheap i7-7700k though)
Mobo: ASRock Z170 Extreme7+  CPU: i7-6700K @ 4.6MHz OC  Cooling: Corsair H115i Hydro  Memory: TridentZ 32GB @ 3600MHz  GPU: EVGA 2070 FTW3 ULTRA+ (OC'd 50/300)
PSU: Corsair HX850i   Storage: 980 Pro 1TB, 950 PRO 512Mb, (2)ADATA SU800 1TB  Keyboard: Logitech G910  Mouse: Logitech G502   Headset: Logitech G930 UPS: APC Pro 1500 S
Unraid box providing network routing, home automation services, and media services ( I love unraid!)
USB Key: SanDisk 16GB Ultra Fit  Mobo: Intel DX79SR Extreme+  CPU: i7-3820  Memory: 16Gb Kingston HyperX Predator  Storage: (cache)480gb Micron SSD (1)8TB HDD (1) 4TB HDD
GPU: MSI GTX 1650 4GT LP OC (passed through to Emby)  NIC: Intel I350-T4 4-port Gb (passed through to PFSense)  UPS: APC PRO 1000
Docker Containers: Emby and Home-Assistant-Core  Virtual machines: PFsense ( I love PFSense!)
Family machines
Mobo: Asus Prime H310M-E  CPU: Intel Core i3-9100F  Cooling: Deepcool Gammaxx 400  Memory: Teamgroup Elite Plus DDR4 16GB  Storage: Silicon Power 1TB NVMe M.2
GPU: Asus GTX 1660 Super 6GB or EVGA 1070 FTW 8GB  PSU: Thermaltake Smart 500W 80+  UPS: APC XS 1300
As well as a number of other machines, a ton of parts, miles of cables, and who knows what else!
Private message me for quicker assistance. I also build and ship custom machines at a really fair price.
https://linustechtips.com/topic/1262649-front-io-mic-input/#findComment-14159036
Looks good,
you might pull the connector and eyeball all the little connectors inside.
I have seen them come loose and push back into the connector housing, and then not make the connection.
Also, do you have the realtek software installed?
If not, install that and see if it works.
Family machines
https://linustechtips.com/topic/1262649-front-io-mic-input/#findComment-14159140
