A while ago my computer started shutting down on random intervals. The event viewer shows nothing of note and I cannot find any other cause that could be responsible than the power supply unit. I have a Corsair GS700 PSU.
Also this error comes up when the computer restarts.
122622885_710443179680055_3347533800204068027_n.jpg.55070a209a1a483405f77ecdb68f5bf5.jpg
Specs of the computer are in the error message. The GPU is a GTX 770 and the motherboard is a Asus Maximus V Gene.
My question is, can something be done about this error or must I replace the PSU?
Thanks for your answers :)
https://linustechtips.com/topic/1261532-random-system-shutdown/
Either your power supply is bad, or the power going into the power supply is very unstable.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/1261532-random-system-shutdown/#findComment-14149043
You might try another power source, especially if you are sharing the wall outlet with multiple devices.
However i agree, this seems like a power supply most likely, i would replace it or swap it for testing if possible.
Also, check your power connections, reseat them all, from the power cord into the power supply, to the power cord that plugs into the board.
Disconnect and reconnect, test at another wall outlet, and if it still happens, replace the power supply.
Daily driver (looking to upgrade mobo and cpu spring of 2021)   --- The only time I sort by price from high to low is when I am shopping for CPU's and GPU's (looking for a cheap i7-7700k though)
Mobo: ASRock Z170 Extreme7+  CPU: i7-6700K @ 4.6MHz OC  Cooling: Corsair H115i Hydro  Memory: TridentZ 32GB @ 3600MHz  GPU: EVGA 2070 FTW3 ULTRA+ (OC'd 50/300)
PSU: Corsair HX850i   Storage: 980 Pro 1TB, 950 PRO 512Mb, (2)ADATA SU800 1TB  Keyboard: Logitech G910  Mouse: Logitech G502   Headset: Logitech G930 UPS: APC Pro 1500 S
Unraid box providing network routing, home automation services, and media services ( I love unraid!)
USB Key: SanDisk 16GB Ultra Fit  Mobo: Intel DX79SR Extreme+  CPU: i7-3820  Memory: 16Gb Kingston HyperX Predator  Storage: (cache)480gb Micron SSD (1)8TB HDD (1) 4TB HDD
GPU: MSI GTX 1650 4GT LP OC (passed through to Emby)  NIC: Intel I350-T4 4-port Gb (passed through to PFSense)  UPS: APC PRO 1000
Docker Containers: Emby and Home-Assistant-Core  Virtual machines: PFsense ( I love PFSense!)
Family machines
Mobo: Asus Prime H310M-E  CPU: Intel Core i3-9100F  Cooling: Deepcool Gammaxx 400  Memory: Teamgroup Elite Plus DDR4 16GB  Storage: Silicon Power 1TB NVMe M.2
GPU: Asus GTX 1660 Super 6GB or EVGA 1070 FTW 8GB  PSU: Thermaltake Smart 500W 80+  UPS: APC XS 1300
As well as a number of other machines, a ton of parts, miles of cables, and who knows what else!
Private message me for quicker assistance. I also build and ship custom machines at a really fair price.
https://linustechtips.com/topic/1261532-random-system-shutdown/#findComment-14149244
