My dragon center hardware monitor keeps saying that my CPU is at 0 C and it keeps slowing down my fans. When I go into Bios my fans seem to be working properly but I really don't know what caused this I've fix it once but it was after clearing cmos but then it just happened again after I shut down my PC and turned it on the next morning. Any details on what it could be is helpful. Thanks
1488263458_DesktopScreenshot2020_10_24-12_23_24.58(2).thumb.png.4cb83f80002da4bb680d51e84ed1902d.png
https://linustechtips.com/topic/1261307-dragon-center-problems/
Is the bios up to date?
Are you using the latest version of Dragon Center? (are you sure? 🙂 )
Whats the hardware background?
Did you build this?
How old is it?
What CPU, mobo, ect
Daily driver (looking to upgrade mobo and cpu spring of 2021)   --- The only time I sort by price from high to low is when I am shopping for CPU's and GPU's (looking for a cheap i7-7700k though)
Mobo: ASRock Z170 Extreme7+  CPU: i7-6700K @ 4.6MHz OC  Cooling: Corsair H115i Hydro  Memory: TridentZ 32GB @ 3600MHz  GPU: EVGA 2070 FTW3 ULTRA+ (OC'd 50/300)
PSU: Corsair HX850i   Storage: 980 Pro 1TB, 950 PRO 512Mb, (2)ADATA SU800 1TB  Keyboard: Logitech G910  Mouse: Logitech G502   Headset: Logitech G930 UPS: APC Pro 1500 S
Unraid box providing network routing, home automation services, and media services ( I love unraid!)
USB Key: SanDisk 16GB Ultra Fit  Mobo: Intel DX79SR Extreme+  CPU: i7-3820  Memory: 16Gb Kingston HyperX Predator  Storage: (cache)480gb Micron SSD (1)8TB HDD (1) 4TB HDD
GPU: MSI GTX 1650 4GT LP OC (passed through to Emby)  NIC: Intel I350-T4 4-port Gb (passed through to PFSense)  UPS: APC PRO 1000
Docker Containers: Emby and Home-Assistant-Core  Virtual machines: PFsense ( I love PFSense!)
Family machines
Mobo: Asus Prime H310M-E  CPU: Intel Core i3-9100F  Cooling: Deepcool Gammaxx 400  Memory: Teamgroup Elite Plus DDR4 16GB  Storage: Silicon Power 1TB NVMe M.2
GPU: Asus GTX 1660 Super 6GB or EVGA 1070 FTW 8GB  PSU: Thermaltake Smart 500W 80+  UPS: APC XS 1300
As well as a number of other machines, a ton of parts, miles of cables, and who knows what else!
Private message me for quicker assistance. I also build and ship custom machines at a really fair price.
https://linustechtips.com/topic/1261307-dragon-center-problems/#findComment-14147701
Did you build this?
How old is it?
What CPU, mobo, ect
I have a
Ryzen 7 3700x
MSI MPG X570 Gaming Pro Carbon Wifi
Crucial Ballistix 16gb 3200mhz
Insignia 550w
I Built it about a month ago and I haven't had any problems with it until now. Also I had updated the Bios to the latest version and I just recently reinstalled dragon center so I believe it is the latest one.
https://linustechtips.com/topic/1261307-dragon-center-problems/#findComment-14147788
Download HDiNFO and see if it reports it correctly. - https://www.hwinfo.com/
How to create a log:
Open HWiNFO and in the bottom right there is an icon that looks like a spreadsheet with a green plus on it.
Click that button to start logging, the green plus will switch to a red X to let you know its saving data.
It will also ask you for a file name and where to save it. I save them to my desktop, name it whatever you want.
Let it run for a few moments or until the machine locks up, resets, or does whatever its not supposed to do,
Then click the spreadsheet again so the red X turns back to a green +.
You now have a log file.
How to view the log file:
You can view the log using the GenericLogViewer addon here https://www.hwinfo.com/add-ons/
Download, extract, run GenericLogViewer.exe, click the open file button in the top right and point it to the log file you made above.
Use the dropdown in the upper right to choose which category to view
You might also share it with us
Family machines
https://linustechtips.com/topic/1261307-dragon-center-problems/#findComment-14147877
Alright just did it. I'm not to sure how this works so hopefully I did this right.
https://linustechtips.com/topic/1261307-dragon-center-problems/#findComment-14148037
Looks like you did it correct. 🙂
Can you share the entire log file with us?
That temp looks right, but might not be the same signal that dragon center is monitoring.
I want to dig through them.
Also, do you know how to boot into safe mode?
Can you boot to safe mode and see if it works correctly?
Edited by cr8tor
more words
Family machines
https://linustechtips.com/topic/1261307-dragon-center-problems/#findComment-14149180
Yes sorry for the very late reply, but is this what you meant by sharing the file? Also went into safe mode and it had no difference.
hj.cfg
https://linustechtips.com/topic/1261307-dragon-center-problems/#findComment-14151050
No, it should be a .CSV file.
When you open HWiNFO, choose the option for Sensors only, and if prompted, hit continue.
Also if prompted, do not download the beta version.
Family machines
https://linustechtips.com/topic/1261307-dragon-center-problems/#findComment-14152079
Oh okay my bad. Here's the actual file.
Dcr.CSV
https://linustechtips.com/topic/1261307-dragon-center-problems/#findComment-14153317
Well this is fun.
hdinfo doesnt report any temperatures either.
I included 2 screenshots, one of your logs, and one that shows temperatures.
 Notice how your logs dont include core temps?
This is yours, notice the dropdown has no options for core temp, its usually the first thing on each core.
This is an example one below
Have you reseated your CPU yet?
If not, for sure do that next.
Edited by cr8tor
spelling
Family machines
https://linustechtips.com/topic/1261307-dragon-center-problems/#findComment-14153323
2 minutes ago, cr8tor said:
Well this is fun.
Oh wow, yeah I'll try that right now.
https://linustechtips.com/topic/1261307-dragon-center-problems/#findComment-14153329
Sweet, let us know how it goes.
High hopes on this one.
Family machines
https://linustechtips.com/topic/1261307-dragon-center-problems/#findComment-14153332
Well my bad, i forgot Ryzens report the cpu temps as a package, not individual cores.
You can see in the dropdown there are a bunch of temps listed and they are there and look ok.
So i think we are looking at a Dragon Center problem.
Let me look into that and see what else i can find.
Family machines
https://linustechtips.com/topic/1261307-dragon-center-problems/#findComment-14153392
You might try creating another windows profile and see if it happens in that profile also.
You sure there is not some other hardware monitoring software running?
Family machines
https://linustechtips.com/topic/1261307-dragon-center-problems/#findComment-14153511
