Hi there, my system with Ryzen 3700X is running at about 60 - 70 degrees celsius under minimal load (Chrome, Discord and a couple other low load apps open)
Averaging around 7% CPU usage in this scenario.
My CPU cooler is the stock Wraith Prism which I'm well aware isn't the best.
So I'm wondering whether these temps are alright.
Thanks
Also, looking at it now, my CPU frequency keeps changing. I know nothing about overclocking other than higher frequencies = hotter and faster.
Is 4.2GHz ok?
https://linustechtips.com/topic/1261053-cpu-overheating-or-not/
Those temperatures seem to be hot for just an idle condition. If your CPU frequency is decreasing while temps increase, then that's thermal throttling.
Is 4.2GHz ok?
Is this straight out of the box and letting AMD boost by itself?
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
https://linustechtips.com/topic/1261053-cpu-overheating-or-not/#findComment-14145508
Yes I haven't touched overclock settings
Been looking into it and downloading AMD's Ryzen Master controller to stop it
I dont need it at 4.27GHz constantly
https://linustechtips.com/topic/1261053-cpu-overheating-or-not/#findComment-14145512
Yes it's thermal throttling then. Keeps jumping from 4.2 to 3.6 and back
https://linustechtips.com/topic/1261053-cpu-overheating-or-not/#findComment-14145517
SEE! Just downloaded AMD's official software and it was on 4.4GHz DEFAULT! what the hell!
https://linustechtips.com/topic/1261053-cpu-overheating-or-not/#findComment-14145528
~Snip~
I would use HWinfo64 (a very extensive program that details everything from voltages/power, temperatures, utilizations, and clock speeds) too and I would clean the old thermal compound off the CPU and CPU cooler and apply new thermal compound (TIM).
https://linustechtips.com/topic/1261053-cpu-overheating-or-not/#findComment-14145530
Ok, will look into that. The PC is only 4 months old and I used Artic AM-4 instead of the pre-applied stuff so it should be fine still.
https://linustechtips.com/topic/1261053-cpu-overheating-or-not/#findComment-14145534
That's odd though but the cooler will provide just enough cooling to run the computer. Perhaps raise the RPM of the cooler's fan and see if that helps? The next option is to get an aftermarket air cooler or AIO for better temperatures.
https://linustechtips.com/topic/1261053-cpu-overheating-or-not/#findComment-14145538
Yeah, I'll adjust the fan curves to see if that helps. I've also been looking into an AIO and will most likely end up getting one to get rid of this constant vacuum cleaner noise in my pc lol. Do you know anything about OCing? What voltages, core clock etc. Trying to change the settings and I know I can mess things up if I don't do it properly.
https://linustechtips.com/topic/1261053-cpu-overheating-or-not/#findComment-14145545
I don't really know much about OCing with Ryzen processors other than from what I've read other users say to never go above 1.325V for an OC but I'd imagine overclocking is similar with pretty much any CPU; set a standard core multiplier and voltage and increase from there incrementally.
There are guides out there on the internet and this one may be of use to you.
https://www.tomshardware.com/features/how-to-overclock-amd-ryzen-cpus
https://linustechtips.com/topic/1261053-cpu-overheating-or-not/#findComment-14145549
Thats not great. My voltage is at 1.375V This is so weird
https://linustechtips.com/topic/1261053-cpu-overheating-or-not/#findComment-14145553
Are settings stock in BIOS? I know there was some reports a couple months back about false readings and I'll provide you the article here but I have to get some rest.
https://www.tomshardware.com/news/ryzen-burnout-amd-board-power-cheats-may-shorten-cpu-lifespan
https://linustechtips.com/topic/1261053-cpu-overheating-or-not/#findComment-14145562
Update: Now set voltage to 1.3V to be safe. Temps INSTANTLY dropped and fans went down. On mobo monitor voltage showing as 1.2V which was reccomended as a good safe level in that tomshardware post. And showing as 3.6GHz constant clock no changing which is good.
https://linustechtips.com/topic/1261053-cpu-overheating-or-not/#findComment-14145566
Yeah settings are all stock apart from RAM which I used a profile to get my full 3600Hz. OC settings I strayed far away from
https://linustechtips.com/topic/1261053-cpu-overheating-or-not/#findComment-14145568
8 hours ago, Olly456 said:
@CommanderAlex Thank you for your help and advice. Its now 4.30am and should probably go to bed :)
Anytime!!
https://linustechtips.com/topic/1261053-cpu-overheating-or-not/#findComment-14146197
