Hi everyone, I've a Gigabyte  gtx 1080ti 11g OCI bought second handed, the card is around 2 years old at the moment and I'm playing at 1440p 144hz which makes the card get to 90 to 100% usage very often (on factory overclock) so the Temps get to target (max 84c) and the fan speed gets to 90% (on custom curve). Question is, should I replace the thermal paste? I read a review in which the card is supposed to be between 37c idle and 77c max temp
https://linustechtips.com/topic/1256674-gpu-thermal-paste-replacement/
