Hi everyone
I live on a island so the climate is humid, and today when I was going to clean my desktop I noticed some kind of water on the I/O cover, on the back of the Gpu (backplate) and on top of the case (inside, was dry).
PC specs:
Asus Rog Strix B360-f gaming;
i5-8400;
Gigabyte 1660 super;
NZXT S340;
Intake fans: 2x Noctua NF-A14 140mm;
Output fans: 2x In Win Polaris 120mm.
I use the stock Intel cooler and have set up the case fans for a positive pressure, right now since the weather here is still warm during games the CPU gets around 70°C and the GPU around 75°C.
I've had this PC for a year and a half and I never had this problem before, to everyone who experienced this before or has any hints I would appreciate it.
Thanks.
I was playing Forza Horizon 4 just today and the PC was working just fine.
https://linustechtips.com/topic/1256220-desktop-forming-condensation-inside-help/
16 minutes ago, Applefreak said:
Looks like water came inside the case somehow. I would not bet on condensation, there would be a lot more droplets on the components. What's your humidity and temperature like at the moment?
The temperature here is around 22°C and the humidity can go from 70-99% on the worst days
