Can someone pls tell me the specifications of the led on mechanical keyboards? Can I just use any 3mm ones? What do you call them?
Also planning to change the stock rgb leds on my keyboard... can I use single colored ones to replace them? stock ones doesn't have a white option... I want a pure white one...
https://linustechtips.com/topic/1255421-changing-keyboard-led/
What keyboard is this?
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/1255421-changing-keyboard-led/#findComment-14096946
19 minutes ago, Loli Pits said:
redragon vara k551 rgb
Can you remove a keycap and take a picture of the switch underneath?
If it uses SMD LEDs, I wouldn't bother changing them. If it's RGB it's probably not realistic to change any LED, but maybe it's possible with through hole ones.
SPECS:
https://linustechtips.com/topic/1255421-changing-keyboard-led/#findComment-14097051
