I am trying to mount a 4*120mm radiator on a cooler master HAF-X case and am having trouble with Clearance of tubing and i have a 80+% blockages on both inlet and outlet to the radiator, what would be the best way of fixing this?
Notes:
I only have a about $25 to spend.
The HAF-X case does not have native support for this size radiator inside case thus it is mounted outside on the back of the case as is on a koolance BKT-HX001, web link (http://koolance.com/radiator-mounting-bracket-with-quick-release).
I live Australia so please take that into account when pricing anything, best website would be pc case gear (.
CPU temps at the moment are around 30 degrees celsius at idle and at 100% load around 60 to 65 degrees celsius
but will reach temps up to 80 to 90 degrees celsius after 5-6 hours running prime 95 or F@H
Rig Specs:
motherboard: GA-X79-UD7 (Water cooled VRM by a EK block,web link (http://www.ekwb.com/shop/ek-fb-kit-ga-x79-ud7-acetal.html)
CPU: intel 3820 @ 4.2 ghz water cooled by a heatkiller rev3.0,web link (http://www.pccasegear.com/index.php?main_page=product_info&cPath=207_160_878_879&products_id=20599)
pump and reservoir: Koolance PMP450s, web link (http://koolance.com/pmp-450s-pump-id-13mm-1-2in)X2 in a RP-452X2 REV1.3 web link (http://www.pccasegear.com/index.php?main_page=product_info&cPath=207_160_299&products_id=18005) pumps are running in serial.
Tubing: 1/2" id 3/4" od
post-15672-0-44134900-1367464074_thumb.j
please feel free to ask any questions needed or request more pictures or info of the rig if that will help.
Thank you for your help
(This is my first time posting on a forum of any type so if this is in the wrong place mods please move it to the right place.)
https://linustechtips.com/topic/12554-first-time-water-cooling-help/
Get some 45 degree angle fittings if you can for the rad, use a bit longer tubing so it's not so tight, and put the grommets back in to protect your hosing from getting cut on the metal of those holes.
Also, I think this is the first real build I've seen that uses those holes on the case. Seems like everyone just mounts their rads inside. Nice to see someone using them as intended.
would these work any better ? http://www.pccasegear.com/index.php?main_page=product_info&products_id=13792 ,i will make my tubing long as soon as i get the time, my case only came with one grommet, could i use some black electric tape instead, good to hear and thank you for the suggestions
I think so. From the picture it looks like you can rotate those to any angle between 0 and 90 degrees so they might work. These were more what I was talking about:
http://www.frozencpu.com/products/11885/ex-tub-735/Bitspower_G14_Matte_Black_Dual_Rotary_45-Degree_Compression_Fitting_CC1_For_ID14_OD_38_Tube_BP-MB45R2CPF-CC1.html?tl=g30c409s1319
Basically your issue is that there isn't enough room between the Rad and the grommet for it to bend up like that, and then back down, without kinking. At least not when it comes out if the Rad at that angle. I think if you use some angled fittings to make it less of a step up from the rad to the grommet, and lengthen your tubing to alleviate the pressure, it will work out that kink. If your case only came with one grommet then yes use some electrical tape, just something to cover that metal edge.
cool, looks like i am going to have to save up bit more money to fix my problem,i see now what the problem is and i was planing to redo my whole loop any way as it is getto riged at the moment and thank you for the help
Maybe make the tubing longer :P That'll push the tubing up into the center of the grommets.
export PS1='\[\033[1;30m\]┌╼ \[\033[1;32m\]\u@\h\[\033[1;30m\] ╾╼ \[\033[0;34m\]\w\[\033[0;36m\]\n\[\033[1;30m\]└╼ \[\033[1;37m\]'
"All your threads are belong to /dev/null"
| 80's Terminal Keyboard Conversion | $5 Graphics Card Silence Mod Tutorial | 485KH/s R9 270X | The Smallest Ethernet Cable | Ass Pennies | My Screenfetch |
You really want the rubber!
Grommets would be much better, but if you absolutely can't get them then electrical tape at a minimum.
should i move i one i have over to one of the tubs for the time being to help the problem if so which one ?
how about these guys facing upwards and then bending the tubing down? http://www.pccasegear.com/index.php?main_page=product_info&cPath=207_160_300_1321&products_id=11733
Yes, there we go. Cheaper than the one's I posted. Go with one of these.
i will add these to the list of things to buy and thank you both for your help
