Hi! i just bought myself a cooler master ELV8 GPU bracket but i cant find the 3pin 5v socket to plug into the motherboard. i have a TUF gaming B450m mobo but have no idea where the connection is to get the rgb to work. please bare in mind this is my first pc build ever and have no clue where it should or shouldnt be and also whether its compatible or not. my motherboard does have aurasync if thats any help.
https://linustechtips.com/topic/1255141-gpu-stand-bracket/
Your motherboard does not have an ARGB header (Addressable RGB) so you would require an ARGB Controller to make use of it, do not plug it in the regular RGB header because that's 12V and it would fry your LEDs
Quote or Tag people so they know that you've replied.
https://linustechtips.com/topic/1255141-gpu-stand-bracket/#findComment-14094277
