So, I have this PC I built myself, which has
-Ryzen 7 2700
-Sapphire RX 580 8GB
-Corsair DDR4 3200mhz RAM 16GB dual channel
-1TB Samsung QVO SSD
-1TB WD Blue 7200 RPM HDD
-Seasonic 80+ Bronze 550w PSU
So my problem is that some games that are usually old give me a blue screen of death if they are not ran through Windows 7 compat mode.
Is there a solution I can try to stop putting every game on the compat mode?
https://linustechtips.com/topic/1254807-bsod-problem/
What bsod codes?
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
https://linustechtips.com/topic/1254807-bsod-problem/#findComment-14091318
1 minute ago, Aeuselft said:
i cant exactly remember the code but it says after "IQRL not less or equal"
reseat the ram. if it continues run the ram with xmp off.
Bios database
prior build:
https://linustechtips.com/topic/1254807-bsod-problem/#findComment-14091345
9 minutes ago, Aeuselft said:
so how does one do that, I suppose it's in the bios but where do I find it? My motherboard is an Asus ROG B450-F
It would be under overclocking. is your ram running at 1600mhz when you check in hwinfo64 or in cpuz? or does it say 1333mhz? (DDR = double data rate. real freq is 1/2 what the bios says.
Bios database
prior build:
https://linustechtips.com/topic/1254807-bsod-problem/#findComment-14091401
