power line wifi adapter kit?
Go to solution Solved by Alfie_Assassin,
You plug the Ethernet from your router into one box (sender box?). That then sends the Ethernet over your houses power line. The other box (receiving box) in the set picks it up from your plug socket, where you can have WiFi or more Ethernet ports. Its slower than if you just had a Ethernet cable directly attached, but more easier to install and use, and allows for more WiFi access points or more range.
Hope this helps.
Hope this helps.
Galaxy: Intel i7 3770k @ 4.5Ghz (Cooled by a h105) - ASUS Sabertooth Z77 - Corsair Vengeance 8gb Ram - Nvidia GTX 780 2 way Sli - Corsair HX850i - Corsair C70
Razer Blackwidow Ultimate Battlefield 4 Collectors Edition (TO BE REPLACED BY K65 RGB) - Logitech G502 - Hyperx Cloud
careful, I had one of those for a long time, and when it died, my ping in every game went from 75-85 to 45-55, I don't know if that is the case for everyone, but that is what happened for me (our house has the most ridicules wiring in the world, consider one of those wouldn't even work in one of our rooms, and one breaker would tern off 3 outlets in the kitchen, 2 in the living room, and 5 downstairs, and it is a mess so it is very possible that it is just because of our pathetic home wiring)
Build: Sister's new build |CPU i5 2500k|MOBO MSI h61m-p23 b3|PSU Rosewill 850w  |RAM 4GB 1333|GPU Radeon HD 6950 2GB OCedition|HDD 500GB 7200|HDD 500GB 7200|CASE Rosewill R5|Status online
Build: Digital Vengeance|CPU i7 4790k 4.8GHz 1.33V|MOBO MSI z97-Gaming 7|PSU Seasonic Xseries 850w|RAM 16GB G.skill sniper 2133|GPU Dual R9 290s|SSD 256GB Neutron|SSD 240GB|HDD 2TB 7200|CASE Fractal Design Define R5|Status online
