I just looking for any tips or information on cable management. Anything is appreciated TIA
CPU: Intel i9 9900K | Motherboard: ASRock B365M Phantom Gaming 4 | RAM: 4x8GB 2666MHz HyperX Fury RGB | GPU: ZOTAC GAMING GeForce RTX 3080 AMP Holo | PSU: Corsair RM750x (2018) | Case: ASUS TUF Gaming GT301 | Cooler: Cooler Master Hyper 212 Black Edition | SSD: Samsung 970 Evo 500GB | SSD: PNY XLR8 CS3030 2TB | SSD: Samsung 860 Evo 2TB | HDD: Seagate BerraCuda 8TB | Monitor: GIGABYTE G27QC
https://linustechtips.com/topic/1254325-cable-management-tips/
cable management for the pc? Or the setup as a whole? You can check out linus's video for pc tho :
PLEASE TAG ME SO I CAN SEE YOUR REPLY!
CPU: AMD Ryzen 7 3700x  | Motherboard: Asus TUF X570 Plus | RAM: Crucial Ballistix 8gbx2 3600Mhz | GPU: Asus TUF RTX 3080 | PSU: NZXT C850 | Case: Corsair 5000D AF | Cooler: NZXT Kraken Z63 280mm | SSD: Samsung 970 EVO 500Gb m.2 ssd + Samsung 860 EVO 1tb ssd | Monitor: LG 49WL95C-W | Peripherals: Logitech G815 + Razer Viper Ultimate + Razer Kraken TE | Audio: Logitech G560
https://linustechtips.com/topic/1254325-cable-management-tips/#findComment-14086906
Just for swapping in a new psu and rerunning the cables.
https://linustechtips.com/topic/1254325-cable-management-tips/#findComment-14086915
Then this video should help you out a lot, it's pretty detailed, but if you're in a hurry, quick tips:
Make sure the cables are in the nearest cable management holes provided, make sure the Bigger cables are over the smaller ones to reduce the bulge ( the 24 pin connector should be over everything else), and cable ties help a ton, other than that, it should be fine :)
https://linustechtips.com/topic/1254325-cable-management-tips/#findComment-14086921
Thank you so much!
https://linustechtips.com/topic/1254325-cable-management-tips/#findComment-14086929
3 minutes ago, Sycoblackburn said:
Thank you so much!
No worries, you're welcome! :)
https://linustechtips.com/topic/1254325-cable-management-tips/#findComment-14086937
