When i was using my pc i felt somthing my performance is slow and i right clicked on my desktop i saw intel hd instead of nvidia control panel help me please. Help would appreciate.
I have updated my drivers and still nothing tried in another dvi slot nothing
My gpu is nvidia gt 730 (thats what i can afford) help me please.
https://linustechtips.com/topic/1253435-gpu-not-running/
Is your monitor plugged into the GPU or motherboard?
Main: AMD Ryzen 7 5800X3D, Nvidia GTX 1080 Ti, 16 GB 4400 MHz DDR4 Linux - Fedora
https://linustechtips.com/topic/1253435-gpu-not-running/#findComment-14079805
8 hours ago, Eth10Mc said:
<snip>
You'll want to reseat your GT 730, it's not appearing to the system. Make sure your display is connected to this GPU, and not the motherboard itself.
https://linustechtips.com/topic/1253435-gpu-not-running/#findComment-14091110
