I built this rig in late December but am just now getting around to uploading the pics of it. I didn't get my graphics card until about 3 weeks after I built the machine, and sadly I didn't have a long enough 8 pin CPU cord (Please Recommend a Good Extender!) The specs are:
Graphics Card: MSI Twin Frozr 7850 OC
CPU: Intel 3570k
Motherboard: ASUS P8Z77-V LE
Case: Cooler Master HAF 912
RAM: 2x4GB Corsair Vengeance
Power Supply: 600W OCZ Modxstream
HDD: Seagate Barracuda 1TB
(I added a DVD drive from an old system later on.)
      If anyone has suggestions for a CPU cooler that could fit with the VERY minimal space between the CPU and RAM, I'm looking to overclock sometime in the future. Also, if anyone knows a fairly cheap and easy way to repaint a case that's something I'm interested in as well, because I feel like the HAF 912 is a good case for that type of project. Thanks for reading and feedback is appreciated!
HAF 912
Before I Added The 7850 (Suggestions for CPU Cooler in that Space?)
My Final Build! (minus the DVD drive)
A Shot of the MSI Twin Frozr 7850 From Beneath
post-17642-0-01454300-1367451772_thumb.j
The Natural Habitat
CPU: Intel i5 3570k @ 4.5 Ghz Cooler: Hyper 212+ GPU: MSI Twin Frozr 3 7850 Case: HAF 912 RAM: 2x4GB Corsair Vengeance PSU: OCZ Modxstream 600W Motherboard: ASUS P8Z77-LK HDD: 1TB Seagate Barracuda
https://linustechtips.com/topic/12506-my-first-build/
is there a reason that you are not running the EPS connector behind the motherboard tray? there is clearly space and the cable is long enough?
MM i did have a Monster Pixo power suply 800 wat suply for 40 bugs mine last like a year a friend of mine 7 days, well that power suply was to short to get the EPS conector behind the motherboard tray. So i gess it thepends on the cable lenght
https://linustechtips.com/topic/12506-my-first-build/#findComment-133200
It looks like it, but it was too short to make it all the way, I'm probably going to get an extender for it because I don't like the way it is now.
https://linustechtips.com/topic/12506-my-first-build/#findComment-133228
