cpu power
Go to solution Solved by Deli,
There are eight 8-pin CPU/GPU socket outputs from the PSU. They can be used either for CPU or GPU. CPU 8-pin cable can be split in to two 4-pin.
I can see that PSU comes with four GPU cables and two CPU cables.
so im buying a asus tuf z490 plus wifi motherboard (link below) and i want to buy a hx850i but motherboard cpu power is a 8 pin and a 4 pin not sure if the psu is compatible as i dont see enough plugs for both
https://www.asus.com/ca-en/Motherboards/TUF-GAMING-Z490-PLUS-WI-FI/
https://www.corsair.com/us/en/Categories/Products/Power-Supply-Units/hxi-series-config/p/CP-9020073-NA
https://linustechtips.com/topic/1249951-cpu-power/
17 minutes ago, Deli said:
I can see that PSU comes with four PSU cables
wat
Think you meant GPU.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
https://linustechtips.com/topic/1249951-cpu-power/#findComment-14047522
