So i recently bought a ryzen 5 2600x and paired with a gigabyte b450m h and 2 dimms of g.skill aegis 8Gb 3000mhz.However when im on windows, even though it recognises the full 16gb, it says only 7.95 of them are usable. I've tried the msconfig thingy and still nothing. I uninstalled one of the dimms and i can use it in full. Only when i use both, one of them is practically useless. Is there anything i can do?
https://linustechtips.com/topic/1249563-hardware-reserved-memory-pls-help/
Does it actually say "Hardware reserved" or are you assuming?
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
3 minutes ago, Dujith said:
Did you install the DIMM's in the correct slots? 1 and 3 or 2 and 4?
the board only has 2 DIMM slots, so kinda hard to mess that up.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
Ah, I didnt look up the board. So thats my bad. :S
As for the OP: Did you try both stick 1 by 1 in each slot? So stick A in slot 1, then in slot 2, repeat for stick B
no, actually only on the first slot. ill try and update with the results
i had this issue with a set of corsair vengeance memory, when it said hardware reserved it meant that one of my sticks was faulty. even though windows detected the full 16gb it left me with 7.96gb ram usable. sent back ram and got a new kit and it worked fine after that.
so from what ive read it may be a fulty stick or maybe even a faulty slot on the motherboard.
Edited by Lord Sephington
When a man lies he murders some part of the world
These are the pale deaths
Which men miscall their lives
All this I cannot bear to witness any longer
Cannot the kingdom of salvation
Take me home
Yep, after trying what Dujith said above, my pc doesnt even boot when i have the one specific dimm, and works fine with the other one. so you are probably right
well hopefully you can get set replaced with something that works, hopefully the place you bought it from has decent customer support and just swaps them out for you.
Take me home
