Don't worry about QVL lists, a 3200 cl16/14 kit or a 3600 cl16 kit should do the job.
Though do you already have this board? It's not bad and it can handle a 3900x but there are other boards that are similarly priced and are a lot better.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1246280-ram-help-3900x/#findComment-14017132
be careful I got the same board but b450 (mby b550 got fixed) I had the issue that RAM wont work stable on even 2933. I tried timings, settings, drive updated, bios update, etc etc. and result is that rams works only on 2866 stable. I tested it on friend PC and rams works on 3200 without any tweaking perfectly fine. So that mobo of mine is at fault.
https://linustechtips.com/topic/1246280-ram-help-3900x/#findComment-14017138
i have not bought yet it was recommended to me as a solid board, what board would you recommend ?
https://linustechtips.com/topic/1246280-ram-help-3900x/#findComment-14017147
Budget? If you're going for an mATX build, the b550 mortar and tuf plus are pretty decent, the mortar uses 8 ISL99360's in pairs for the vcore and the tuf plus uses 8 sic638's.
These are two different boards. And there could be many things for the cause of that. Not necessarily the board.
Edited by TofuHaroto
Build Log:
https://linustechtips.com/topic/1246280-ram-help-3900x/#findComment-14017149
Idk what can be other than that, just Im careful with that lineup of the boards B series as its the only things that left not touched in my case.
https://linustechtips.com/topic/1246280-ram-help-3900x/#findComment-14017157
everything you said is a bit above my knowledge lol ill deffs look into those 2 tho
the only real ram ive found that meets what you said without going crazy expensive is this
https://www.umart.com.au/G-Skill-32GB--2x16GB--F4-3200C16D-32GFX-Flare-X-3200MHz-DDR4-RAM_56006G.html
https://linustechtips.com/topic/1246280-ram-help-3900x/#findComment-14017200
I'm going to assume prices where you live are a litt high.
But yea any 3200 cl16/14 or a 3600 cl16 kit should do the job for the most part.
Build Log:
https://linustechtips.com/topic/1246280-ram-help-3900x/#findComment-14017205
