Most of the top tier 3rd party RTX 3080 cards comes with 3 X 8pin power delivery.  Im currently using a Coolermaster Masterwatt 750W PSU that I purchased 6 months back and it has 2 dedicated 8 pin ports on the PSU.
The weird part is, the cable that I connect into the PSU's 8pin port splits into 2 x 8pin. Example shown below.
so will this be ok if I plug into my future rtx 3080 card? will I have any power issues?
https://linustechtips.com/topic/1246231-rtx-3080-psu-issue-help-needed/
Absolutely do not do that, you have to use separate PCIe cables.
Especially since we don't know how much power these cards are going to draw.
If it's a 3x 8 pin unit it will likely have a high power draw.
What model number is that PSU?
i9 9900K @ 5.0 GHz, NH D15, 32 GB DDR4 3200 GSKILL Trident Z RGB, AORUS Z390 MASTER, EVGA RTX 3080 FTW3 Ultra, Samsung 970 EVO Plus 500GB, Samsung 860 EVO 1TB, Samsung 860 EVO 500GB, ASUS ROG Swift PG279Q 27", Steel Series APEX PRO, Logitech Gaming Pro Mouse, CM Master Case 5, Corsair AXI 1600W Titanium.
i7 8086K, AORUS Z370 Gaming 5, 16GB GSKILL RJV DDR4 3200, EVGA 2080TI FTW3 Ultra, Samsung 970 EVO 250GB, (2)SAMSUNG 860 EVO 500 GB, Acer Predator XB1 XB271HU, Corsair HXI 850W.
i7 8700K, AORUS Z370 Ultra Gaming, 16GB DDR4 3000, EVGA 1080Ti FTW3 Ultra, Samsung 960 EVO 250GB, Corsair HX 850W.
