Specs:
CPU: AMD Ryzen 7 3700x
Motherboard: Gigabyte B450m DS3H WiFi
Ram: 32 GB (2x16GB) DDR4 3200 mhz
GPU: Zotac RTX 2060
Storage:
Adata XPG SX8200 Pro 512 GB NVME M.2
2x 4TB WD Red NAS
PSU: EVGA BR 700w
Case: Corsair iCue 200T RGB Case
I plan to switch to a fully modular gold psu in the future and make the cabling red and white. Additionally would upgrade the motherboard
https://linustechtips.com/topic/1245987-my-first-build/
Check those WD Red drives. They're very likely SMR, which ironically is not intended for RAID (the ironic part, since that's the entire point of these drives). Write are *stupidly* slow as well, with it sometimes taking days to properly sync, meaning you can lose data in the meantime.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
https://linustechtips.com/topic/1245987-my-first-build/#findComment-14014512
