Help picking ram
Go to solution Solved by RaphaNadal,
Be careful - I swapped out G.Skill Ripjaws V 3200 MHz CL16 RAM for Ripjaws V 3600 MHz CL16 RAM. Check the QVL for your RAM\Motherboard combination to make sure you are good to go. I didn't.
I run R7 3700X on B550 Gigabyte Aorus Pro, and the 3600 MHz RAM is causing the system to go into a boot loop. I didn't have this issue with 3200 MHz RAM.
Limited run of Memtest is revealing zero issues (21\21 tests passed). I'm willing to let Memtest run for 7-8 hours overnight, but I think the RAM itself is fine, it's just not compatible with R7 3700X\B550 Aorus Pro combination.
Really bummed that I will have to go back to the store and return RAM for a second time.
I am gonna build a new pc for the new 30 series and amd CPUs and wanted to know what would the best ram to get?
Corsair or G Skill -
G.Skill Trident Z RGB Series 16GB (2 x 8GB) 288-Pin SDRAM PC4-28800 DDR4 3600 CL18-22-22-42 1.35V Dual Channel Desktop Memory Model F4-3600C18D-16GTZR
Corsair Vengeance RGB Pro 16GB (2x8GB) DDR4 3600 (PC4-28800) C18 AMD Optimized Memory – Black
Which one would be better?
https://linustechtips.com/topic/1245817-help-picking-ram/
You should always try to find a kit with a CAS latency of 16 or lower. A 3200 CL16 kit is often faster than a 3600 CL18 kit. Something like this would work well.
Main PC:
AMD Ryzen 7 5800X • Noctua NH-D15 • MSI MAG B550 Tomahawk • 2x8GB G.skill Trident Z Neo 3600MHz CL16 • MSI VENTUS 3X GeForce RTX 3070 OC • Samsung 970 Evo 1TB • Samsung 860 Evo 1TB • Cosair iCUE 465X RGB • Corsair RMx 750W (White)
Peripherals/Other:
ASUS VG27AQ • G PRO K/DA • G502 Hero K/DA • G733 K/DA • G840 K/DA • Oculus Quest 2 • Nintendo Switch (Rev. 2)
Laptop (Dell XPS 13):
Intel Core i7-1195G7 • Intel Iris Xe Graphics • 16GB LPDDR4x 4267MHz • 512GB M.2 PCIe NVMe SSD • 13.4" OLED 3.5K InfinityEdge Display (3456x2160, 400nit, touch).
Got any questions about my system or peripherals? Feel free to tag me (@bellabichon) and I'll be happy to give you my two cents.
PSA: Posting a PCPartPicker list with no explanation isn't helpful for first-time builders :)
https://linustechtips.com/topic/1245817-help-picking-ram/#findComment-14013245
Cant you change the timing or something in the bios? Sorry still new to pc.
https://linustechtips.com/topic/1245817-help-picking-ram/#findComment-14013253
7 minutes ago, Apple50000 said:
Do you have a link to them and are they on amazon?
This is the kit I was talking about
https://linustechtips.com/topic/1245817-help-picking-ram/#findComment-14013256
CAS Latency (CL) is usually represented by the first number in your RAM's timings, but it exists at the hardware level, so it can't be changed or optimized in BIOS. It's pretty similar to gray-to-gray response time in a monitor, in that more latency is always worse for your system.
Main PC:
Peripherals/Other:
https://linustechtips.com/topic/1245817-help-picking-ram/#findComment-14013262
Understood thanks, I will check out the rip jaws kit.
https://linustechtips.com/topic/1245817-help-picking-ram/#findComment-14013303
https://linustechtips.com/topic/1245817-help-picking-ram/#findComment-14013362
