Hello all, yesterday I asked for help and I got some! I really appreciate that. Anyways, a member named "AndreiArgeanu" suggested that I use the Lenovo T540. I have reviewed it, and it seems it would fit all my needs. I am not quite sure this computer it really what it says, for around $780, you could get a i5-9400, 8gb or ram, and a 1660 Ti. I would like to know if anyone has any experience with this pc. I'll post the link so you all could check it out. :)
https://www.lenovo.com/us/en/desktops-and-all-in-ones/ideacentre/500-series/IdeaCentre-T540-15ICB-G/p/99IC9500324?IPromoID=LEN351111
https://linustechtips.com/topic/1245666-pc-help-d-again/
10 minutes ago, Savion Kirby said:
Hello all, yesterday I asked for help and I got some! I really appreciate that. Anyways, a member named "litttrash" suggested that I use the Lenovo T540. I have reviewed it, and it seems it would fit all my needs. I am not quite sure this computer it really what it says, for around $780, you could get a i5-9400, 8gb or ram, and a 1660 Ti. I would like to know if anyone has any experience with this pc. I'll post the link so you all could check it out. :)
Um, that wasnt me false credit lmao
https://linustechtips.com/topic/1245666-pc-help-d-again/#findComment-14011910
