When playing modern warfare I get around 90-100 FPS but this is no matter what settings I play on. I have put my setting on all low and 720p and it keeps around 90-100 frames and I have put it on higher settings 1080p and it stays at 90-100 FPS I am not sure why. If someone could help me thanks!
specs
cpu- Ryzen 5 2600 3.85 ghz
gpu- rx580 8gb
ram- Corsair 16gb 3200mhz
https://linustechtips.com/topic/1245315-need-help-with-fps/
specs
gpu- rx580 8gb
I think I know your problem. Have you turned on XMP in the bios? Because RAM doesn't run at full speed unless that turned on.
PM/DM me if you have any questions about audio.
My PC specs & audio gear
CPU > Intel core i7 14700K, GPU > RTX 4070 ProArt, RAM > Corsair Vengeance DDR5 2x16gb 5600mhz, Motherboard > Asus ROG Strix B760-F, Storage > 1TB M.2  & 500GB M.2 Kingston, Cooling > H150i Elite, PSU > MSI A850GL
🎧Current Audio Setup🎧
HifiMan Ananda Nano, HE400se, X2HR
Soundblaster AE-9 Soundcard
AKG P420 Mic
Other peripherals
Monitor > Samsung Odyssey OLED G9
Keyboard > Keychron Q3 HE TKL
Mouse > Logitech G Pro 2 Lightspeed
Mousepad > X-Gamer XG++ XXL mousepad
Read this post if you want a "gaming" headset ;)
https://linustechtips.com/topic/1245315-need-help-with-fps/#findComment-14009215
RAM speed actually makes a big difference. Also are you running with 1 stick or 2? Your processor is probably contributing to lower fps since warzone is really CPU demanding. I get like 130-144fps with my i7 9700k
AKG P420 Mic
Other peripherals
https://linustechtips.com/topic/1245315-need-help-with-fps/#findComment-14009218
I’m running 2 sticks how do I turn xmp on
https://linustechtips.com/topic/1245315-need-help-with-fps/#findComment-14009542
Search on google
AKG P420 Mic
Other peripherals
https://linustechtips.com/topic/1245315-need-help-with-fps/#findComment-14010762
